After replacing the drum unit on a Ricoh Aficio 200 and turning the power on, in mid initial cycle a SC-542 error code and service wrench comes up. After hand cranking the timing wheel in behind the rear cover of the machine so the drum unit could be removed and checked re-inserted the drum unit still have the code and wrench .
Do I have a fuser problem, or is there an sp code to reset the service code?
