mpc2003 "toner waste disposable unit" replacement procedure
  • Mark Bbb
    • Jun 2012
    • 1662
    Hello,
    Does anyone know this procedure?
    And also:
    Did you also noticed that some pcdu's are rather tight in there position in the machine then others?
    I mean, when you remove the screw which hold the pcdu in place, some pop out immediately, while others needs "a forcy pull" to get them out...
    Does anyone know if this is normal? And if not, what is the trick to get it wright?
    Thanks!!!
  • Mark Bbb
    • Jun 2012
    • 1662
    Re: mpc2003 "toner waste disposable unit" replacement procedure
    Originally posted by Mark Bbb
    Hello,
    I don't mean the toner disposable box, i mean the whole assembly unit with gears, pipes, and whatever....
    • davel
      • Oct 2011
      • 1107
      What procedure, pull it out, put in empty one.
      Yes, ricoh's quality control has gone to the toilet.
