MPc3002 printer font error
  • tufbnme
    • 493
    Never seen this before, can't find how to fix it.
    Also, Installed Postscript and the machine will not recognize it, tried slot 1 and 2.
    Any advice?
  • StephenB
    • Aug 2015
    • 246
    Re: MPc3002 printer font error
    What OS ? Driver ? and are you sure the problem is not from the print application ?
    Also, the PS option cannot be "used" only installs once.
    • solorajder
      • Jul 2010
      • 106
      Did you have Java SDcard installed? I have the same problem on MPC4502 when it was without Java SD card.
      Sent from my I9195I using Tapatalk
      • tufbnme
        • 493
        Yep, Java card is missing, probably it. Now I have to find the card.
        • solorajder
          • Jul 2010
          • 106
          The Postscript doesn't work because it is probably merged on mising java sd card
