af 1022
  • Gab
    • Aug 2015
    • 671
    af 1022
    when i put a certain drum unit machines message is that there is no drum unit and to insert one. It only happens with one certain unit . When i insert an other unit is ok. Where is the problem in this unit?
  • tufbnme
    • 493
    Re: af 1022
    Apparently.
    • sandmanmac
      • 3981
      Re: af 1022
      I had the same problem when I was changing a light bulb today. I can't figure it out.
        • 37488
        Re: af 1022
        The machine is not seeing the toner density sensor.
