Hi Guys
I have been tasked with upgrading the firmware on a ricoh MPC2051 copier as our ricoh guy has left overnight (great) l am Canon Man!! and not sure about the technique on the ricohs. We were sent the SD card from a Ricoh dealer with the firmware already installed. There are two sd card slots on the machine(which both have cards installed at present) i assume one of these cards is removed and the firmware card fitted in its place to carry out the upgrade. I have in the past upgraded the mpc2500 which if l remember correctly was just a case of installing the said sd card switch machine and the reset was done from the display. If anyone can help as to whether the same applies to the mpc2051 it would be appreciated
UK Rog
UK Rog
