MPC 4500
  • Users Tech
    • Nov 2013
    • 85
    MPC 4500
    Hi to all,
    SC-293 on the screen then we took out the shutter of the laser unit and then we accessed sp mode to clear the sc code but when we pressed copy sp it won't go in. copy sp will just appear again. Maybe the operator of the machine (resigned already) changed some settings because we didn't have this problem when we serviced this machine before. All buttons are functioning. Hoping for your help.
  • Brianneoe
    • May 2015
    • 321
    Re: MPC 4500
    Its been a few years but i believe you need to set SP 2914-001 or 002 to a 1
    2914 [Dust Shield Shutter Motor]
    001 Stop Delay: Open *ENG
    002 Stop Delay: Close *ENG
    DFU
    [1 to 50 / 38 / 1 ms/step]
    003 Open Execution *ENG
    Opens the shutter on the laser optics
    housing unit manually for test purposes.
    004 Close Execution *ENG
    Closes the shutter on the laser optics
    • Users Tech
      • Nov 2013
      • 85
      Re: MPC 4500
      [QUOTE=Brianneoe;587330]Its been a few years but i believe you need to set SP 2914-001 or 002 to a 1
      How can i set it if i can't access copy sp?
        • 37513
        Re: MPC 4500
        Service mode lock is in User Tools - System Settings - Admin Tools is turned on.
        • Users Tech
          • Nov 2013
          • 85
          Re: MPC 4500
          Strange.. Can't access system settings too. when i press it, it will just make 2 beeping sounds and won't go in. i don't think the sc792 that appears on the screen has something to do with it. When i opened the machine, the sc293 is gone but can't copy or access copy sp, system settings and can't even print the counter.
            • 37513
            Re: MPC 4500
            You might need to log in. After you enter User Tools, a login button should appear in the upper right of the touch screen. Login name is Admin with no password. It that doesn't work, then someone has changed it. You will need to login as Supervisor again with no password. If that has been changed as well, there are many threads here on how to reset admin and suoervisor passwords. If you can get in as Supervisor, the only thing that the Supervisor can do is change the Admin credentials. You can then login as Admin
            • Users Tech
              • Nov 2013
              • 85
              Re: MPC 4500
              the login button did not appear in the screen after entering user tools.
              • eddy out
                • Oct 2016
                • 359
                Re: MPC 4500
                user tools/sys settings/administrator tools/admin authentication mgmt/set admin authentication 'on'/enable administrator tools. then back out to get your login button.
                • bob marley
                  • Jan 2012
                  • 1339
                  Re: MPC 4500
                  Hi to all,
                  SC-293 on the screen then we took out the shutter of the laser unit and then we accessed sp mode to clear the sc code but when we pressed copy sp it won't go in. copy sp will just appear again. .
                  u don't need to reset sc 293 using sp ( Turn the operation switch or main power switch off and on.) ,if it is still there after removing the shutter then the next step is to replace the shutter motor.
                  Live for yourself and you will live in vain. Live for others, and you will live again
                  • Users Tech
                    • Nov 2013
                    • 85
                    Re: MPC 4500
                    i thought it's the same with other sc error that you have to reset it. sc 293 is gone but the problem is i can't copy, access copy sp, access system settings in the user tools and no login button appeared on the screen after entering user tools. is it a faulty hard drive? i searched for solutions and what i saw was the same with slimsbob (thank you).
                      • 37513
                      Re: MPC 4500
                      Can you access using WIM? You can do almost everything with WIM as you can with User Tools.
                      If you know the Factory SP code try using it.
