Ricoh mpc2050 toner out
  • vga_man
    • 78
    Hello!
    After reinstall a new oem black toner cartridge... Copier made only 186 copy then toner cartridge became empty ☺
    Any ideas?
    • 37544
    Re: Ricoh mpc2050 toner out
    OEM is not the same as Genuine Ricoh. OEM merely means manufactured to Ricoh's toner menu, i.e. the same ratio of components. It does not mean to Ricoh quality or quantity.
    That said, take the cartridge out and shake it. Does the cartridge feel like it is empty? If not, you could have a bad RFID chip on the cartridge, a bad RFID board in the machine or a bad toner supply motor.
    • vga_man
      • 78
      It's empty..
      • fshead
        • 2376
        Originally posted by vga_man
        It's empty..
        i always ck aftermarkets to see how much toner is really inside b4 trying them...
        even use a scale to compare
        • sturmtrooper
          Copier Combobulator
          • May 2016
          • 587
          It's empty..
          Sounds like you got taken for a ride then.
          • mikadonovan
            • May 2008
            • 2931
            I suppose it's possible to do that at heavy density and close to 100% fill.
            NEVER ASSUME ANYTHING
            • fshead
              • 2376
              i have seen some non oems out there that look like starter toners,meaning like 1/5th of what you get in OEM..
              If you have a real issue your waste bottle will fill up fast.....and you will know as that toner needs to go somewhere
