Firmware Update
  • mtebka
    • Dec 2013
    • 38
    [Misc] Firmware Update
    Good day
    I have a MP301spf(D128) which came up with error "waiting for firmware update data" ipv4 address: 010...... I tried to update the system firmware via remote. The machine had error SC 819 before. Most of the firmware was up to date except for the sys/copy, scanner, printer and opepanel.
    Anyone got any ideas of how I can solve this one?
  • Zeldaman
    • Mar 2011
    • 946
    Re: Firmware Update
    Hi there!
    Would try it with the sd-card.
    Greetings...
      • 37532
      Re: Firmware Update
      Corrupted System/Copy firmware - reload.
      An optional board, if any, attached to the controller board defective - replace.
      Controller board defective - replace.
      • mtebka
        • Dec 2013
        • 38
        Re: Firmware Update
        I have tried to reinstall system/copy firmware using sd with no luck. I will try to trouleshoot the boards 1 by 1. Will update any progress. thanks guys
        • francisco
          • Nov 2009
          • 168
          Re: Firmware Update
          Originally posted by mtebka
          Good day
          hy
          i had some problema last week with a MPC305 ,the nvram was damage.change fix the issue.
          • hanspeter75
            • Mar 2010
            • 37
            Re: Firmware Update
            try a sd-card with all firmware for the MPC305.... i mean 10-15 files.
