Ricoh LD325 copying blank pages after drum replacement
    • 36890
    #16
    Re: Ricoh LD325 copying blank pages after drum replacement
    Originally posted by r00tb33r
    please don't just tell people to contact an authorized service provider. Share the info!
    There are times when it requires eyes on by a tech with experience with the particular model. There are also times when not knowing exactly what to do, such as firmware updates, can cause damage that will cost you hundreds of dollars.
      Yep. Probably the culprit.
      Do I have to take it (it, the drum unit) apart to load it up with developer?
      yes. where are you going to get the developer? are you a tech?
      • copyaction
        • Oct 2007
        • 985
        #18
        Happy ending. Bought and received developer, took apart the drum unit and poured it in around the delivery screws. Did not need the service manual. Reset the counter and initialized developer successfully. Machine makes good, clean prints now.
        Thanks for all the help, and please don't just tell people to contact an authorized service provider. Share the info!
        I knew it the second I read it, You are welcome
