Ricoh Mpc 4501 sc582
  • duplicators
    • Apr 2016
    • 63
    Any idea thanks
    Enviado desde mi Moto E (4) mediante Tapatalk
  • AUWI
    • Jan 2018
    • 7
      • 37653
      Re: Ricoh Mpc 4501 sc582
      Jumper the thermostat connector on the IH Inverter board. If the machine then works, the thermostat located on the IH coil is tripped. The last I heard, Ricoh does not sell just the thermostat. You have to replace the entire IH coil assembly.
      • TonerMunkeh
        Professional Moron
        • 3865
        If you need it up and running quickly, put some blu-tac on the stat and pull it off quickly. That will reset it so it's dome-shaped again, but it won't last long.
        Hit it.
        • mikadonovan
          • May 2008
          • 2931
          That's a damn good idea, TM. Only have to pull the coil once at replacement.
          NEVER ASSUME ANYTHING
          • TonerMunkeh
            Professional Moron
            • 3865
            It's gotten me out of the poop a few times.
            Hit it.
              • 37653
              I tried it once. Didn't work. I had to bypass the stat at the connector on the inverter while I waited for a new coil.
              • Lagonda
                • Aug 2008
                • 1649
                Do that around here and your be looking for a new job by the end of the day! Bodging or bypassing safety systems is a big no-no that will get you more then a smack on the wrist if something goes wrong.
