Ricoh 1232c SC570
  • wrecketbeckett1
    Ricoh 1232c SC570
    what code is on this P.O.S.?
  • JustManuals
    • Jan 2006
    • 9838
    Fusing Oil end.
    You're welcome.
    Paul@justmanuals.com
    • wrecketbeckett1
      oils full??
      • cobiray
        Passing Duplication Xpert
        • Mar 2008
        • 1199
        Empty
        • Shadow1
          • Sep 2008
          • 1642
          Upgrade
          73 DE W5SSJ
          • pspahr
            Toner Schlep
            • May 2008
            • 227
            L
            O
            L
            VectorLinux---Check it out!
            • wrecketbeckett1
              P.O.S.
              How about a SC590?? LOL This thing needs an enima!
              • JustManuals
                • Jan 2006
                • 9838
                no thanks
                the keyword here is 'thanks'
                • knobby
                  • 75
                  You will need to do R 107 hold c/s 5 seconds, then in copier sp mode enter 7914 (oil counter reset) then 1930 to add oil to sump.
                  If no joy it'll be the sensor on the oil bath or pump packed up or air block etc.
                  hope this helps
