MPC4502 SC552-03
  • Hadster
    • Aug 2011
    • 264
    MPC4502 SC552-03
    Heating roller warm-up error 2
    after the inverter turned on.
    2. The temperature at the end of the heating roller does not reach the
    ready temperature for 89 seconds after the fusing lamp turned on.
     Defective heating roller thermistor
     Defective inverter
    This is copied from the service manual. Can someone please tell me what the inverter is?!! When I do a search for inverter the only thing that comes up is with the duplex door.
    I have a SC552-03.... which I don't even know what the 03 stands for because that is not listed in the manual as well.
    I have replaced the whole fuser and would love to know what a 03 code and a inverter is!!!!!!! Very frustrated!
  • Zeldaman
    • Mar 2011
    • 946
    Re: MPC4502 SC552-03
    Hi there!
    Good to know that the US-manual is as "shitty" as the german one. The german word for "inverter" means, that it is the duplex-unit(?????), and the -03 exists not. Only explanation is a bad thermistor.
    But the meanest thing is the german translation of the METIS C-1 range. Read loud in the workshop, everyone is crying and/or laughing.
    Greetings...
      • 37529
      This model uses an induction heater, IH. The inverter is the IH Inverter. In the service manual replacement section it is refereed to as the AC controller board.
      • ruben
        The New Guy
        • Oct 2012
        • 1203
        The MPC4502 uses a dual lamp system for heating, no induction unit.
        The inverter it specifies here may be a poor translation or cross-over from a previous model. My bet is on the latter.
        For me SC552 has always been a faulty fuser sleeve, either the sleeve is torn or the lamps have snapped.
          • 37529
          The translation of inverter to AC Controller Board is still proper for the service manual trouble shooting of SC522-03.
          • Hadster
            • Aug 2011
            • 264
            Update! The customer is 4 hours away so I was just trying to be prepared before I went. I had replaced the fuser on the last call so I felt pretty sure that would not be the issue. Turns out is was... a bent over thermistor! Slightly bent to one side not making full contact. Still not happy about service manual. Thanks as always for everyone's input.
            • fshead
              • 2376
              i like the old old days of lamps and heater triacs
