Can I make a mpc400SR into a MPC400?
  • fshead
    • 2375
    HI
    I am picking up a mpc400 next week with the sorter unit pretty much beat to crap from movers.
    i have a spare c400 in shop with 600k that i wont resell.
    can i pop covers off or is there more to this?
    thnx
    • 37421
    Re: Can I make a mpc400SR into a MPC400?
    I know that models with an optional internal finishers, the copier will still function with the finisher option completely removed. Have had to do so a few times when waiting for parts for the finisher. The service manual replacement and adjustment section does provide how to remove the internal finisher for repair. I would start there then compare the C400SR with finisher removed to the C400 to determine what is next. You might just need a couple of covers around the paper exit area.
    • sandmanmac
      • 3980
      Slim's right.
      I've done this once in the past -those units are really a pain to remove, but yes, it's just a matter of installing on the Exit tray cover, (and possibly a couple of other smaller ones), but also remving the 3 or 4 metal supports that sit under the finisher to support the extra weight of the unit, and unless removed, they'll prevent the installation of the regular exit tray cover.
      • fshead
        • 2375
        Originally posted by sandmanmac
        Slim's right.
        thanks i ve done it with the mpc 2551 where the small internal finished got smashed by movers.
        when i get it i will look at it and let you know
        • fshead
          • 2375
          Well I saw the machine yesterday when picking up my mpc3003 and c3002s and
          its a complete pig..must have been in a dirty warehouse..
          can never make it look good unless i pull everything out.
          So now its will be stripped for parts..
          thanks anyway
