Lanier 5445, Ricoh AF450e question
  • Baphomet
    Copier Technician
    • Aug 2008
    • 293
    I need to order the plastic cartridge which holds the staples in the finisher. In my parts book it has the entire stapler assembly minus the cartridge. The finisher is the one with product code A697 ... console type. I KNOW I have ordered this thing in the past, but I cannot remember where I got the part number. If anyone can help me with a part number I'd sure appreciate it.
  • E Winter
    Staple cartridges are usually consumables like toner and not listed in the parts guide. You'll get a new plastic holder + some refill packs if you arder a new set.
    Unfortunately I can't access the necessary informations here at home.
    • mrgoodcopy
      TechMgr
      • Dec 2007
      • 49
      The staple code is 9353, these are the Savin numbers that cross over to the 5445.
      9353Staple Cartridge Type 7 " F" for SR700/SR710/SR730/SR740/SR800/SR870/
      SR900/ST28/ST28P/ST30/ST31/ST31P/ST33 (Finisher Accessory # 5170 SS-8 (20 BIN) Accessory # 5182 Finisher # 5190/SS-11 # 6441 SS-Punch 12 # 6442 Finisher # 6444 / Finisher #9 383)
      2035DP 2045DP 2050 2055DP 2060 2065 (JPN) 2070 2070DP 2555 9500 9600 9700 9800RF 9935D 9935DP 9935DPE 9940DP 9940DPC 9945DP 9945DPE 9950DP 9955DP 9965DP SDC410 SDC410E SDC413 SLP45 1- Full Cartridge & 4 Refills; 5,000 Staples per CartridgeST28209338
      • Baphomet
        Copier Technician
        • Aug 2008
        • 293
        Thanks guys, that was all it took to jog my memory. It IS a supply item and I got it on order already. Thanks again ...
