PCDU units MPC3001
  • GeorgeBest
    • Jul 2009
    • 526
    PCDU units MPC3001
    Hi
    Question; are the PCDU units with this model compatible with the MPC3000, C2500 series ?
    Not sure, thanks in advance
  • gellyman
    Re: PCDU units MPC3001
    you can use the d029-2256 (mpc 4000-5000) pcu's for the color ones.
    file down connector in back of pcu, swap two wires around on connector in front of pcu, and modify the frame base on machine. theres a piece of metal that slides into pcu in the rear. just cut that off with a tin snips.
    • ridgemill
      • Sep 2017
      • 190
      The drums are the same, you can use either B224-2042 or D029-2269 for both Bk and colours.
      Developer is different, so they will need to be replaced separately.
      To use the older style drums you will need to swap the wire on the connector, cut the corner to fit the connector inside the machine, and remove the metal pin inside the machine.
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Here is a attachment on drums B224 2042
        Regards Mark
