ricoh mpc 4501
  • mrgene
    • 53
    ricoh mpc 4501
    so I bought a 4501 with no print controller. Can i replace the print controller with a different one ? if so how
    thanks
  • davel
    • Oct 2011
    • 1104
    Re: ricoh mpc 4501
    Controller is built in.
    • sturmtrooper
      Copier Combobulator
      • May 2016
      • 587
      Re: ricoh mpc 4501
      thanks
      As mentioned the print function for this machine is built into the controller board PCB and is not an option. If you bought this machine and it is physically missing that board you will need to buy a new one, the external panels for it, HDD bracket and HDD and a 2GB memory SODIMM
      D5515710 is the part number for the board itself, it is quite expensive though. You can only use the controller board made specifically for the C4501, not one for any other machine.
      If you bought the machine and it has all its circuit boards but the print function is not working you will need to troubleshoot the problem.
