Ricoh Aficio 3030 cannot copy double side, shows duplex mode is in off position trays
  • ttean
    • Oct 2010
    • 32
    Ricoh Aficio 3030 cannot copy double side. When double side is selected on the display, the top display shows duplex
    mode is in off position with all trays. The duplex unit is already installed in the copier.
    Single side copy no problem and is working well.
    Thx
    alvin
  • Elmo
    • Feb 2010
    • 541
    Re: Ricoh Aficio 3030 cannot copy double side, shows duplex mode is in off position t
    Read your user manual and turn it on
    user tools -- tray settings duplex on/off
    or to reset all settings to default
    user tools hold down # key and touch system settings
    I Used To Live To Fix Things Now i Fix Things To Live
    • ttean
      • Oct 2010
      • 32
      Hi Elmo,
      No need to turn it on unless use computer to do printing. For photocoping we need only to press copy for 2 sided copy only. Normally for two sides photocopy when the duplex unit is installed in the copier when we select 2 sided copy the copier will not shows this error message on top of display. Anyway I try to to reset the copier
      and see.
      Thx
      alvin
      • davel
        • Oct 2011
        • 1089
        Tray settings - paper type I believe it is near the bottom right, duplex off.
        • ttean
          • Oct 2010
          • 32
          Thanks, after resetting to factory default the machine can do duplex printing
          Alvin
          • Mark Bbb
            • Jun 2012
            • 1662
            RTFM = read the f*ck*ng manual...
            • Mark Bbb
              • Jun 2012
              • 1662
              sorry
