mp c3002 sc 997
  • ABS tect
    • Sep 2013
    • 511
    mp c3002 sc 997
    Customer was getting 997 code sporatically....wondering what might be causing this? Something they are doing or a software problem with the machine? I went there and did a firmware update but the problem is still happening.
    Not sure how to troubleshoot because when it happens they never seem to remember what they were doing
    997 B
    Application function selection error
    The application selected by the operation panel key works abnormally
    (No response, abnormal ending).
    1. Software (including the software configuration) defective
    2. An option required by the application (RAM, DIMM, board) is not
    installed.
    3. Nesting of the fax group addresses is too complicated.
     Check the devices necessary for the application program. If
    necessary devices have not been installed, install them.
     Check that application programs are correctly configured.
     For a fax operation problem, simplify the nesting of the fax group
    addresses.
     Take necessary countermeasures specific to the application
    program. If the logs can be displayed on the operation panel, see
    the logs.
  • rsyarcia
    Hair Straightener Tech
    • 711
    Re: mp c3002 sc 997
    have you updated all the firmwares?
    Nobody is perfect..
    • ABS tect
      • Sep 2013
      • 511
      Re: mp c3002 sc 997
      Yes
      • Polarbear
        • Feb 2012
        • 1070
        Re: mp c3002 sc 997
        Hi
        Can you post images of the SC pages of the SMC report please?
        Press the GREEN button!!
        • TonerMunkeh
          Professional Moron
          • 3865
          Re: mp c3002 sc 997
          If it's running anything Java, check the heap and stack aren't maxed out. I normally set them to 75% of their maximum. On the MPC4000/5000, I had a lot of 997's at a particular customer that were only sorted with a scanner memory clear.
          Hit it.
          • ABS tect
            • Sep 2013
            • 511
            Re: mp c3002 sc 997
            Is it most likely something that they are trying to print from their computers?
            I printed out the sc report and it looks like the more frequent code is sc-899...which when i have come across that i just emptied the customers print q and that took care of that code.
            Anyways looks like sc-899 and sc-997 are the issues on this guy. But i know i updated the firmware, ill post it and you can check if it is the most recent..seems to me though like it is something they are trying to send to the copierSC Report.pdfFW.pdf
            • cadillac2
              • Oct 2015
              • 42
              Re: mp c3002 sc 997
              do sp7403-001 and post a pic of what it shows on the screen
                • 37500
                Re: mp c3002 sc 997
                Anyways looks like sc-899 and sc-997 are the issues on this guy. But i know i updated the firmware, ill post it and you can check if it is the most recent..seems to me though like it is something they are trying to send to the copier[ATTACH]38761[/ATTACH][ATTACH]38762[/ATTACH]
                Before you emptied the customer's print q did you check to see what the first job in the q was. If it was a web page, there in is the most likely source.
                In the future, it is easier to compare the firmware levels if you print the diagnostic report SP 5990-005 or export it SP 5992-005. This is a one page report that has all the firmware information on it.
                Have you updated JAVA as it can also cause SC 899. Doesn't appear on you're attachments. With JAVA SC899 may occur when the machine recovered from energy saver mode. There are other JAVA caused SC 899 they are dependent on what peripheral and Apps are using JAVA. JAVA firmware history is rfg054280 on rfg-esource.
