MP C4500 j054 on 11x17
  • Qball
    • Jun 2013
    • 127
    [Jamming] MP C4500 j054 on 11x17
    • 37560
    Re: MP C4500 j054 on 11x17
    Trail edge does not clear bank vertical transport sensor 2 within the allotted time. Check paper size code in SP 7504. It should be 160. Also check jam count for 11X17 SP 7506-160. If the size code is not 160 and the count in Sp 7506-160 is too small, you have a problem with the size switch for tray 4.
    • Qball
      • Jun 2013
      • 127
      I will check that out! Thanks, Slim!
      • Qball
        • Jun 2013
        • 127
        Also, I just replaced the IO board. No change.
          • 37560
          Originally posted by Qball
          [ATTACH]38868[/ATTACH]
          My mistake, SP 7504 is the total since reset for each jam code. You have to look at the SP 7507-XXX on the screen and not on the SP 5900-004 print out. On the printout it just gives the jam number, date/time and counter. On the screen it also shows the paper size. Search the Service Manual for paper size code. Should be in the jam detection section.
          • Qball
            • Jun 2013
            • 127
              • 37560
              A0h is hexadecimal. Convert to decimal.
              • Qball
                • Jun 2013
                • 127
