Ricoh MPC 3002 with fiery, can i enable scan option?
  • fshead
    • 2356
    ok
    I just picked up a low meter c3002 and it has fiery controller option which i got to boot up and see on op panel.
    I dont see scan option.
    is the scan option shut down when you disable the default print option?
    should i ck the sd card if it is showing scan/print?
    thanks in advance..
    plus any way to copy the fiery hard drive in case the hard drive goes out?
    i was thinking of using a "GHOST" like program,acronis to make a tib image
  • Athlontini
    • Jun 2012
    • 269
    Re: Ricoh MPC 3002 with fiery, can i enable scan option?
    If you install Command Workstation on a PC and connect it to the Fiery, you can back it up from there.
    When you install a Fiery, you disable the built-in print and scan functions. It is possible to re-enable them if you take the Fiery out of the equation; otherwise you will have to scan thru Command Workstation
    • zed255
      How'd ya manage that?
      • 1024
      The native GW scanning can be enabled with the Fiery installed. Scanning via Fiery leaves much to be desired.
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3945
          • 36833
          Fiery scanning is done through the command console.
          If the previous user was using Fiery scanning and you wish to use GW scanning change SP 5895-002 back to 0. You will need 2 network connections. The Fiery requires a network connection and connects to the MP C3002 via the gigabit the connectors on each. The MP C3002 GW connector is used for scanning.
          • fshead
            • 2356
            thanks all
            i backed up the nvram and then reset everything back to 0"5895-01 and 02 and 5193-01 and now it comes up in screen..
            NOW my query is i have this machine sold but the customer has no need for fiery..
            can it be installed in a different machine if i pull the gigabit connector?
            • jonhiker
              • 661
              yes, you can re-use the fiery on a different copier
                • 36833
                Originally posted by fshead
                thanks all
                You have to remove the Fiery ICON from the home screen, change the SP 5193-001 and SP 5895-001 back to 0 and remove the gigabit Ethernet PCB.
                The Fiery E-3300/E-5300 can be used on MP C3002/3502/4002/4502. You would have to check with EFI to see if it is usable on any other machines. You could also sell it on Ebay.
                • fshead
                  • 2356
                  thanks
                  I dont see too many fierys on lease returns so i hate to not use it when a account with need for it arises..
                  EFI I dont feel will be too helpful...
