Ricoh MP-c2500 Black Drum Unit 2 versions?
  • tecchie
    • 120
    I currently have a customer with a Ricoh Aficio MP-C2500 that's in need of a black drum unit. Is there an old/newer version to this drum. I checked and double checked my drum order and machine model. I have a genuine ricoh drum unit for the mp c2500 but it doesn't fit. If there is 2 versions can this one be modified. Please respond. Thanks.
  • mikadonovan
    • May 2008
    • 2931
    Re: Ricoh MP-c2500 Black Drum Unit 2 versions?
    B2232244. The only one I know of.
    NEVER ASSUME ANYTHING
    • sandmanmac
      • 3981
      What's the P/N you have?
      The number was changed to B2242042 years ago, when they modified the charge roller assy, but either will fit
      • tecchie
        • 120
        That is the part number on the box. It looks like the front cover is a little different than the one i took out. Ill investigate further.
        • sandmanmac
          • 3981
          Front cover, and drum stays are different. You can't use the old covers with the new pcu's, and vice versa, as far as i can recall
          • jonhiker
            • 661
            you are correct, just toss out the old cover and use the new one
