Ricoh MPC2500 cannot print coloured JPG.
  • richard lee
    • Jun 2014
    • 13
    [Misc] Ricoh MPC2500 cannot print coloured JPG.
    Hi,
    We have a Ricoh MPC2500. We can print coloured PDF but cannot print coloured JPEG.
    The message said that we are not authorized. (something like that).
    Is there a setting for this?
    Thank you.
  • amir ricoh
    • Feb 2018
    • 5
    Re: Ricoh MPC2500 cannot print coloured JPG.
    hi if u cannot print colour better u check your driver printer set colour or black white, if set colour please login web image & checking your acces colour enable or disable
    • richard lee
      • Jun 2014
      • 13
      I can print PDF format in colour. Jpeg can print in black and white but not in colour.
      • amir ricoh
        • Feb 2018
        • 5
        Yess that why i say you check your driver printer mybe in the driver printer set black white not colour if set black white no wander you cannot print colour
        • richard lee
          • Jun 2014
          • 13
          is already in colour. Default is in colour.
          • amir ricoh
            • Feb 2018
            • 5
            Make sure your driver printer at AVANCED(printing defaults) set colour then PRINTING PREFERENCES set colour is not same set no wander you cannot print
            • davel
              • Oct 2011
              • 1108
              Open the jpg file, click file,print, select printer properties, I bet that Black and White is selected.
                • 37560
                You might want to check the file permissions of the jpeg. What software are you using to open and attempt to print the jpeg with or are you just trying to right click and select print.Have you tried using IrfanView?
                  no he said they CAN print color PDF's .... just not JPEGS.
                    yess that why i say you check your driver printer mybe in the driver printer set black white not colour if set black white no wander you cannot print colour
                    damn
                    man... Read he -= can =- print color pdf's... Not jpegs....
                    • richard lee
                      • Jun 2014
                      • 13
                      Thank you all,
                      Was doing trial and error, and discovered this..
                      -open jpeg file with photo - print only B&W
                      -open Jpeg file with Windows Photo viewer - print only B&W
                      -open Jpeg file with paint - can print colour
                      -open Jpeg file with snagit - can print colour
                      -Open Jpeg file with paint 3D - can print colour
                      I was using the top 2 all these while. Damn..
