SC202 of Ricoh SP320DN
  • docsconsulting
    • Feb 2018
    • 9
    [Error Code] SC202 of Ricoh SP320DN
    I posted this yesterday but in the wrong forum.. I read through the manual and still cannot see where the polygon mirror motor is located on the machine. or is there a way to reset this code. Inside the left cover all the other motors are working.
    Mike
    • 37533
    Re: SC202 of Ricoh SP320DN
    In most models it sets on top of the laser housing.
    • Gary Bowen
      Bowdog
      • Mar 2008
      • 250
      Your Laser Housing is just below the Exit area and above the AIO. You will need to remove literally every external cover to access the Laser Housing and the Polygon Mirror Motor inside the Housing.
      • fshead
        • 2376
        Mike
        too bad you didnt post this last week i just gutted a working low meter one and left all the boards and laser as i only wanted the drums,fuser and ITB unit
        • laitang
          • Nov 2012
          • 627
          Mike
          In Service manual:
          Page 39: Laser unit
          Page 40: Polygon mirror motor
          • docsconsulting
            • Feb 2018
            • 9
            Do you still have the polygon motor?
            • docsconsulting
              • Feb 2018
              • 9
              Gary,
              Is it attached to the Exit cover? i see that under the cover.....will look again.
              Mike
              • fshead
                • 2376
                no i tossed the boards and laser unit..
                if i am not mistaken on other machine a bad laser will smoke the board when it goes,so changing just
                the laser might not be the answer..
                i am in your neck of the woods..
                • docsconsulting
                  • Feb 2018
                  • 9
                  thanks,
                  First it cam up with fuser needs replacement, then SC202....Either polygon mirror motor or bad board? Not sure if its worth fixing as the motors are not cheap
                  • fshead
                    • 2376
                    thanks,
                    SC 2xx (Laser Optics Error)
                    202
                    Polygon motor on timeout error
                    The polygon mirror motor does not reach the targeted operating speed within
                    1
                    0
                    sec.
                    after turning
                    after turning.
                    Polygon motor/driver board harness loose or disconnected
                    board defective
                    Laser optics unit defective
                    1.
                    Turn the machine main power off/on.
                    2.
                    Replace the interface harness of the laser optics unit.
                    3.
                    Replace the laser optics unit
