MP161
  • tcypy1961
    • 773
    [Misc] MP161
    Copier has offsetting issue. Replaced upper fuser roller twice & lower fuser roller once. Afterwards offsetting would go away yet (not sure number of copies made) after about a week offsetting would be back. The last thing replaced was the PCU, offsetting instantly went away. Came back today a month later for routine ck-up and offsetting is back along with raised toner feel on paper. What might I be missing??? The toner I use in this copier is the same used in several other MP 161's being serviced with no problems. Also looks like copier has a major bias leak(haze over copy) or overtoning & once again PCU is new with a little over 10,000 copies.
    Thanks!!!
  • sandmanmac
    • 3981
    Re: MP161
    Wondering why you'd replace fuser rollers a couple of times? If unsure of the source of the issue (PCU or fuser), stop the copy.
    The 'haze' all over the copy surely indicates it's not the fuser.
    Did you initialize the PCU at install?
    Also...this "same" toner you're referring to is apparently not Genuine OEM, so you can NEVER rule that out. The trouble with generics is always that they can change their "recipe" at anytime to save themselves a few pennies in manufacturing.
    I've had my fair share of experience with Generics, but they inevitably fail at some point and the cost of time and consumable loss very quickly eats up all that previous "savings".
    The only generics or compatibles I'll use are monocomponent machines (mostly AIO cartridges)
    • Iowatech
      Not a service manager
      • 3930
      Re: MP161
      When the problem went away right after the PCU was changed was when you should have suspected the toner.
      • andy227
        • Jan 2013
        • 219
        Re: MP161
        I second everything everyone said about the toner.
        Well of course it would. The new PCU is preloaded with OEM dev/toner isn't it ? Then the crap toner works its way in and everything goes to sh#t.
        of course it will overtone, that is one of symptoms of crap toner. The PCU was new until you put the crap toner. Now that dev is useless.
        I never understand the false economy of putting 'compatible' toners. I see them every day because my bosses are cheapskates and order us to take those toners. Especially in the big machines such as mp 6000's etc, those toners literally destroy the copiers. There is more toner dumped inside the machine than on the copies. I am fuming with anger every time I go to one of those.
        • Mark Bbb
          • Jun 2012
          • 1662
          Re: MP161
          no copy-paper can be the issue...
          1. inform customer that paper can be the issue.
          2. If hot roller is not smooth anymore, replace it.
          3. make a copy with paper from your office; OK? No need to replace the pcu again...
          Not ok? Replace pcu.
          Customer may not use the paper anymore which he uses now.
          It could be that preprinted paper is the issue...
          • eddy out
            • Oct 2016
            • 359
            Re: MP161
            I follow your perspective, but curious how the cq issue was resolved immediately after a pcu change. I am realizing that Amazon is now even selling copy paper, along with several bottom shelf "COPY PAPER" choices. These low cost paper choices are increasingly causing issues with my machines, although usually jamming while duplexing and extreme paper dusting everywhere.
            • Mark Bbb
              • Jun 2012
              • 1662
              Re: MP161
              • MIGUELMARCHENA
                • Feb 2018
                • 195
                Re: MP161
                with this same model and generic toner the same thing happened to me.
                that crap of toner damaged everything
                changed unit and very well as he began to charge that poison and again wrong
                before the disbelief of the owner asked for a change of toner, I did not want to, take mine
                and full
