i want to move aficio mp w2401 to other place !
  • jakani
    • Dec 2014
    • 147
    Hello everyone ,
    i have an aficio 2401 machine and i want to move it , but the main machine won't separate from the roll feeder !
    any suggestions are much appreciated
    thank you
    • 22808
    Re: i want to move aficio mp w2401 to other place !
    Originally posted by jakani
    Hello everyone ,
    thank you
    please explain " roll feeder"
    if you are talking about where paper exits ( finisher ) open door.... there should be a lock/unlock handle there.. remove the screw closest to the handle.. pull handle out..separate finisher from main body.
    • mikadonovan
      • May 2008
      • 2936
      Look at the rear of the machine down by the lower frame area. You can see the screws holding the roll feeder to the machine frame on either side. Should be 4 screws, If I remember right.
      NEVER ASSUME ANYTHING
      • mikadonovan
        • May 2008
        • 2936
        It's a wide format, no finisher.
          • 22808
          wow thanks.. maybe I should keep quiet'
          • jakani
            • Dec 2014
            • 147
            thank you very much for your help
            • limo
              • Jun 2008
              • 101
              use the installation procedure but from end to start
