Scan to folder question
  • fshead
    • 2376
    hi
    I am placing a MPC 300,low meter as a backup to an account a good ride from me and need to know
    will I be able to configure scan to folder on theit window8 and 10 based pcs?
    i scanned a firmware page and couldnt see anything in the bulletins ..
    thanks in advance
  • mikadonovan
    • May 2008
    • 2931
    Re: Scan to folder question
    After looking at the Diagnostic report, negative. The scan to folder windows 8 fix was network support firmware version 10.59. 10.58 won't work with 8 or 10. On a note, many of your other module versions are not up to date, either.
    NEVER ASSUME ANYTHING
      • 37462
      System/Copy needs to be at 2.07 or later in order to support 10.59 network support. That makes at least 2 firmware that are not current. Current System/Copy is 2.10.
      • hdmr
        Helpdesk Engineer
        • Feb 2013
        • 51
        I too have documentation that supports this should work on Windows 8 and 10.
        Firmware release was back in 2013.
        • fshead
          • 2376
          It matches my 1999 toyota tacoma,old but reliable......
