Ricoh 03's magenta pcu
  • ABS tect
    • Sep 2013
    • 511
    #16
    Re: Ricoh 03's magenta pcu
    another reason i was asking was i noticed something in sc mode output mode that i hadn't before on other models....if you get to the toner supply motor section
    (142-155)...only the magenta one has a second option that says "Toner Supply Motor M:CW: (ITB contact)"
    Also the other one has CCW: Standard rather than just Standard
    What is that about?
      • 37362
      #17
      What is that about?
      CW means Clock Wise
      CCW means Counter Clock Wise
      • Vincent128
        • Sep 2015
        • 348
        #18
        Originally posted by fshead
        I too tried to save money on my 1060 to mp6001 and took a beating in toner dumping and shading copies.....
        I worked for a company that was a Ricoh dealership....every year or so when they would burn through a service manager the new servicemoron would decide we needed to use NAtraiding drums...they were inconsistent garbage and as if Ricoh's did not have enough toner control issues, these made it way worse. "Sir, these drums only last half the life as OEM and developer lasts 1/3 if that and the clutches and drive system is not forgiving when the dev unit puked all into them" "Servicemoron~ But they cost half as much! so just look at all the money to be saved!" We had good luck with certain Kaytun drums but only on a few Konica models.
        • fshead
          • 2360
          #19
          CW means Clock Wise
          I kinda thought the same
          • fshead
            • 2360
            #20
            I stopped using KATUN drums,fuser rollers etc
            after burning thru rebuilding 20-30 ricoh 220 drum units.....
            There are some really solid drums made from Germany and Japan but one should
            really visit the NOMDA conventions..I did way,way back as an excuse to go to Vegas
            but saw a lot of suppliers out there..
              • 37362
              #21
              The biggest problem I have had with 220/270/1022/1027/2022/2027 PCU rebuild kits has been POS cleaning blades that are so soft that they fail in less than 2 weeks and start giving offsetting.
              • fshead
                • 2360
                #22
                hmmmmmmmm..
                i found the drums to scratch and start to show thin lines.........i always covered each drum with starter powder b4 putting charge roller unit
                back on and would spin drum on new blade but 4-8 weeks later drum lines
