MP 3351 print isue
  • jrob416
    • May 2011
    • 112
    [Misc] MP 3351 print isue
    Working with a MP 3351 that occasionally prints what I call "gibberish". Prints letters and characters across top of page and nothing else. Most times it prints the documents with no issues. I have updated printer and pcl firmware, with no success. This has just recently started and is rather annoying for all involved. Thanks in advance for any suggestions.
  • davel
    • Oct 2011
    • 1097
    Re: MP 3351 print isue
    Update all firmware and use latest PCL6 driver, if it only happens on pdf files change/update pdf reader.
    • StephenB
      • Aug 2015
      • 239
      Is this is happening in a clients office ? Do you witness it ? It may be someone else has an incorrect print driver pointed at your MP 3351's IP address.
      Change the IP, and use a pcl 5 driver ( pcl 5 is a more basic driver)
      More details would be helpful
        • 37412
        Sounds very much like a drive issue. Exactly what will happen if a job is sent to a laser using a dot matrix driver or visa versa. Will also happen from a momentary drop of network connection during job header information transmission.
        • jonhiker
          • 661
          agree on the driver issue. I have seen the same thing with someone using a postscript driver on a machine without postscript.
          • Choro1dal
            • Jun 2008
            • 176
            Do any of the pages of gibberish contain the string ' get / http / 1.0 ' or similar?
            If so, check that your customer's IT support are not conducting any penetration testing.
            If not, the usual suspects are endpoints with a print queue configured with a queue using a print interpretor (DRIVER) that isnot supported by the device. In a server centric environment I would configure an ACL on the device only allowing the print server's IP access.
            • Iowatech
              Not a service manager
              • 3930
              I've been offline for a while so take what follows with a grain of salt.
              But when I saw this back in the day it was mainly caused by bad print jobs, typically because an Adobe Acrobat (pdf) file was malformed, or a website was defective.
              In those cases, if the source was first taken as a screenshot, the paper print would be fine.
              Sometimes you can try that out by printing the problem media to a file first, and then observing it before you print to paper.
              Like others have said before this, it could be a bad printer driver too.
              Sorry if this was a waste of time.
              • AjitN
                • Mar 2009
                • 287
                Printing from which PC, OS inf.
                Long time back I remembered there was Virus During win XP or win ME time, which used to print garbage on top of the page ( few lines only)
                That was very old & I do not think it could be but just check, may be helpful.
