I have a Ricoh 1224c in the field that starting sending and receiving 'garbage' when faxing......any ideas, or has the fax board just gone bad? Thanks, Debi
1224c Fax
Try printing out the service monitor report. if that shows errors then it may be a line issue, is it from all numbers that you get this problem?
You could even try a fax memory clear (last resort) if its on all numbers, have a look at the journals to see if they print out ok and let me know what you get.Networking skills are advantageous but use of a 3m vacuum cleaner is essential -
I had a 2022 that was doing a similar thing when sending. I ended up turning off ECM, clearing the fax NCU and formatting the HDD. Make sure print out or save the fax destinations, print information and scanning info before formatting or clearing anything.the savin2535 is displaying well bet the hiter lamp is not shining and the lamp had been tested o.k.please kindly help.Samir: No, not again. I... why does it say paper jam when there is no paper jam? I swear to God, one of these days, I just kick this piece of shit out the window.
Michael Bolton: You and me both, man. That thing is lucky I'm not armed.Comment
Thanks for the reply and i think i have found the issue, we loaned the customer a new machine which worked...then a few days later it didn't. This is when i went ino the comms room and decided to remove the adsl filter (disabling there broadband temporarily) and got our office to send a fax, it worked!!! Anew filter of a different brand (higher quality) has been fitted and so far it has worked.Networking skills are advantageous but use of a 3m vacuum cleaner is essentialComment
This customer bought the copier used, so I just went into the SP5?? mode and set to factory settings. All is working fine now. Thanks for the help.Comment
