gestetner 10512 /sc-101
  • DIONISIS
    • Oct 2008
    • 17
    i have a machine with a continusly fault sc101.
    machine display the code at power up and when the optics initialized the white level expossure at doc glass white bar.the lamp switch off!
    i 've replaced: 1)exp.lamp 2)lamp regulator 3)lamp ribbon cable 4)scan mot 5)MCU pwb 6)PSU 7) scan drive pwb 8) ldc pwb
    BUT NOTHING GOOD HAPPEND!!!!! THE SC101 IS STILL THERE.....
    give me any idea you have!!
    THANKS
    DIO-masterprint
  • Shadow1
    • Sep 2008
    • 1642
    Is the White Ref intact and clean?
    73 DE W5SSJ
    • cobiray
      Passing Duplication Xpert
      • Mar 2008
      • 1199
      I had an issue with a 9002 that required the lens block to need replaced. You might want to try reseating the connectors and cleaning the lens first.
      • DIONISIS
        • Oct 2008
        • 17
        today i replaced lens block and the ccd(assembly) but nothing happend.
        i think tha is a
        damaged cable beetwen mcu and image proc pwb!
        thanks anyway!!
        DIO-masterprint
