DF3040 ARDF jams
  • gestetner tech
    • Nov 2009
    • 45
    DF3040 ARDF jams
    Hi folks
    i am having a strange papper jam on this feedr. It can jam after 1 papper and then it can work 50 pappers and no jam
    I have mounted new feedrollers and rubber band and retard roller, checked the sensors in service mode.
    It always stops on the same place all the time. see photo
    i have cleanded the rollers in papper path.
    I am out of ideas.
    any help ?
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Re: DF3040 ARDF jams
    Is it only jamming on hole punched originals (as pictured)?
    • gestetner tech
      • Nov 2009
      • 45
      Hi no
      But i found the problem, The skewsensor are looking at some velvet material supposed to be Black it was a very thin layer of dust on it reflecting. so the sensor thought that the papper was still there.
      • mrwho
        Major Asshole!
        • 4299
        Originally posted by gestetner tech
        Hi no
        You beat me to it.
        Mascan42
        Ibid
          • 37422
          Hi no
          Very common problem. Machines in high dust environments need to be cleaned regularly.
          • Vincent128
            • Sep 2015
            • 348
            Remember the black felts that sensors would look at? .. black sharpie was always part of Total Call Procedure..could not clean the things for crap, you just painted all the dust black.
              • 37422
              Canned air has always worked for me and is a lot faster.
              • Vincent128
                • Sep 2015
                • 348
                old school analog machines - the felt would kinda melt'ish and no matter what you did, white specks would stay stuck in the felt.
                The bigger minoltas's would puke ozone and the heat from those 2 halogen exposure lamps would make things worse, we had the same problem with analog ricoh and the 350/1030 series.
