Richo mp c4503 not properly fusing/savin mp c4503
  • jper34
    • Sep 2011
    • 225
    Hi folks,
    having intermittant trouble with this copier not always fusing, mostly on 1 side, when it does happen. I did replave the fuser film"oem", along with the LFR. Is there a temp adjustment that can be made ( or should I even consider that)..?
    It only seems to be black, I have replaced drum, not developer yet. are there ant physical adjustments that I could consider..?
    Thanks for ant help ..!
    Jaime
  • andy227
    • Jan 2013
    • 219
    Re: Richo mp c4503 not properly fusing/savin mp c4503
    Toner toner toner toner................are ye of the of the 'good' stuff, or are ye of the bottom of the barrel stuff, pray reveil thou self...
      Originally posted by jper34
      Hi folks,
      Jaime
      are you sure the paper type is set properly in the trays and driver?
      • sandmanmac
        • 3981
        I agree with Andy227 on the toner, and also, was this a problem before or after you replaced the fusing film/assy??
        http://www.copytechnet.com/forums/ri...ht=#post592258
          • 37480
          Hi folks,
          OEM does not mean the same as Genuine Ricoh, or Sharp or Canon or any other manufacturer. OEM only means to the manufacturer published specifications. It does not mean the same quality of construction or materials as Genuine.
          Also check that in User Tools it is set to Driver/Program and not to Machine Setting if the problem only occurs when printing.
