MP5002, SC672-00 intermiately
  • mdtrinh
    • Aug 2010
    • 68
    [Error Code] MP5002, SC672-00 intermiately
    I am facing an issue with SC672-00 on MP5002.
    It will happen during middle of copy/print job, machine stop and reboot, then SC672-00 show up, paper remained jam before registration roller, all other area clear. Power cycle machine, everything ready to operate, but it will stop after about 5 or 6 copies, reboot, SC672-00, paper remained before registration roller.
    I did format hdd, remove finisher, remove hdd, reseat all memory, double check op panel connectors seating firmly.
    I also check inverter motor harness routing, seem to be ok according to Goose's Guide.
    I am running out of item to check.
    Please help.
    • 37627
    Re: MP5002, SC672-00 intermiately
    There is a loss of communication between the controller and the operation panel. Common cause is the USB cable going to the operation panel not fully seated and vibration causes a loss of connection.
    • Cipher
      It's not easy being green
      • May 2006
      • 1309
      Could be a number of things to be honest, it's a case of trouble shooting really.
      Plus you say it's intermittent, only during a copy/print run.
      • I would start with checking the power socket with Martindale tester and checking the earthing continuity of the machine. (poor earthing during operation can cause lots of weird faults).
      • If that checks out ok then I would re-seat the controller PCB and all the connectors and memory DIMMs and do the same with the ops panel (it could possibly be a faulty memory DIMM).
      • Then reflash all the firmware.
      After that you would be looking swapping parts around / out etc.
      • FrohnB
        • Jul 2017
        • 1919
        I've run into some different fixes for this code on several different models. Just some things to check/ solutions I've had;
        Swap IPU board - Savin 9033
        Replace Op Panel - Several models
        Replace controller - MP 4002
        Replace HDD - Several models
        But one, that had me stumped for a week or better, turned out to be the simplest - It was on a Savin 9228 and after replacing nearly everything, turned out to be that the small MBU board on fax unit was not seated fully.
        Again, just some things to check.
        Omertà
        • laxlaw
          Please help.
          someone wrote before to check the fuse
          • chothuemayphoto247
            danson
            • Jan 2021
            • 8
            Lỗi SC 672 May Photocopy Ricoh La Gi ? Cong Ty Lam Sơn Anh
