Ricoh aficio SP 5210 SF loud noise and error code SC-202. is this a laser error??
  • tonerjockey
    • Apr 2014
    • 567
    Hi guys, i am trying to determine if this in fact the laser scanner motor error??
    thanks JIm
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Re: Ricoh aficio SP 5210 SF loud noise and error code SC-202. is this a laser error??
    If it's a high pitch whirring sound then I'd say so.
    • Coptech
      worker drone
      • 460
      Noise aside, the most common cause of 202 codes on those things is the front door is not closed on the left hand side. It activates the laser shutter.
