SC 672
  • Sanchez2409
    • Sep 2024
    [Error Code] SC 672
    Have a Ricoh that had a blank display panel called ricoh had me replace the BCU board display came back but still have sc 672 with no start up. Have replaced Contoller/IOB/BCU/NV RAMS/ MEMORY DIMMS. ANY HELP would be great.
  • FrohnB
    • Jul 2017
    • 1919
    Re: SC 672
    What model machine are you working on? Did it have a "black" screen before replacing those parts? Does it have a fax unit?
    Omertà
    • ?09317
      • Nov 2017
      • 8
      Re: SC 672
      you can check whether the power supply fuse is blown,if you replace the fuse and then blow it, replace the IH circuit board first and then replace the fuse .
      • laxlaw
        Re: SC 672
        GM, was it the fuse or did you solve the problem some other way
        • davel
          • Oct 2011
          • 1033
          Re: SC 672
          We still have no idea what model he is asking about.
