MP 4002 SC878-01 Bad controller board right?
  • havokprod
    • Oct 2012
    • 159
    Anything else to look for? Any other tips? Can I use a donor board from a known working machine?
    TIA
    -Aldo
    • 37480
    Re: MP 4002 SC878-01 Bad controller board right?
    You will need to swap the NVRAM and possibly need to reenter the serial number if you get a SC995 after doing so.
    • sandmanmac
      • 3981
      I'd try reflashing F/W first (if you can). Otherwise, controller
      • havokprod
        • Oct 2012
        • 159
        Tried re-flashing at the customers..... No dice..... did not get the firmware menu after 15 mins of waiting. Installed a full set of donor boards, customer up and running but wrong meters etc etc. Gonna try NVRAM swap at the office to another set of boards, I will update. Thank you Slimslob and Sandmanmac for the suggestions.
        -Aldo
          • 37480
          -Aldo
          The counters are saved in the NVRAM.
