Ricoh PRO C 651
  • info@digitaalprint.be
    • Aug 2016
    • 33
    [Error Code] Ricoh PRO C 651
    Can someone tell me what to do with code C719-3.
    Machine has just moved but has made copies.
    Patrick
    • 37556
    Re: Ricoh PRO C 651
    It is in the service manual. If you don't have a service manual, you should not be working on a production printer.
      • Aug 2016
      • 33
      Re: Ricoh PRO C 651
      I have the service manual, but I can not believe that the print is broken. I do not believe in coincidence. Must be a stupidity. Maybe someone had the same error ...
      • TonerMunkeh
        Professional Moron
        • 3865
        Hit it.
          • Aug 2016
          • 33
          Re: Ricoh PRO C 651
          Originally posted by TonerMunkeh
          SC719-3 - Downstream HCS Communication Error
          The unit installed immediately to the left of the HCS failed to respond.
          • HCS I/F cable disconnected, loose, or broken
          • HCS main board harness disconnected or broken
          • Main machine controller harness disconnected or broken
          • HCS main board defective
          • Main machine controller board defective
          Something's been damaged in transit or it's not plugged in.
          The stacker was corrupt. Machine also said that the toner was not properly placed + code sc719-3 and sc719-7.All because of the stacker that was corrupt. just so you know.Thank you everyone.Patrick
            • 37556
            Re: Ricoh PRO C 651
            Who moved it?
              • Aug 2016
              • 33
              Re: Ricoh PRO C 651
              Who moved it?
              a set idiots
