Baron copying speed
  • fatfingers73
    • Feb 2013
    • 219
    [Misc] Baron copying speed
    Hi all,
    I've got two identical 8110's running the same firmware.
    When copying one scans roughly twice as fast as the other.
    I've checked that all copy settings match.
    Any ideas?
    Thanks and happy Friday
  • ridgemill
    • Sep 2017
    • 190
    Re: Baron copying speed
    Is this scanning speed when feeding the originals or communicating to the scan destination?
    What is the scan resolution set to?
    Are both scanning to the same IP address / hostname? Or, one to hostname one to IP?
    Full colour / auto colour, or B&W set as default?
    PDF or PDF/A? (PDF/A are generally larger, as more font information is embedded).
    • fatfingers73
      • Feb 2013
      • 219
      Hello, thanks for your response.
      This is for copying only.
      • imaginemoko
        unTrusted Tech
        • Jan 2008
        • 289
        i would suggest to try swap the dev unit of this two Baron and lets see.... we encounter before a faulty TD sensor. :best of luck
        fix the customer first then fix the machine... its simple and makes life more easy.
