Aficio MPC C305SPF
  • Taminol
    • 171
    Aficio MPC C305SPF
    Hi all you friendly Ricoh engineers!
    I'm a tourist from the Konica Minolta board but need a little help prior to visiting a Ricoh.
    We have a client who has all KMs on site and an old Ricoh MPC C305SPF.
    The Ricoh keeps asking for Yellow toner, which the client informs us they have changed. But it still asks for it to be replaced.
    Not sure if it will be a chip which needs cleaning, a generic toner issue (they say it genuine) or something else.
    Is there anything you guys know about this prior to our visit?
    Taminol
  • ridgemill
    • Sep 2017
    • 193
    Re: Aficio MPC C305SPF
    Common problem with these machines, faulty toner hopper. It is very difficult to replace, as you need to remove the entire rear section.
    D117-3303 for colour, D117-3302 for black.
    • DRichard
      • May 2008
      • 482
      Look at Service Bulletin-012 for Ricoh D117/D118.
      "Enjoy every sandwich."
      -- Warren Zevon
      • Zaxxon
        • 608
        First time, this is a 3 hour job. Good luck and may the force be with you.
        Please start you post with brand, model, problem.
        • Batman1976
          • Jun 2016
          • 91
          Yeah, Replace Yellow toner hopper. Or I would suggest picking a window and throwing it through it....................
          • Zaxxon
            • 608
            This would be my first choice too.
            • Taminol
              • 171
              You're all singing the same tune, which gives me great confidence in your diagnosis.
              Thank you so much for your contributions :-)
              • Polarbear
                • Feb 2012
                • 1070
                Could also be the toner detector board. They have poorly designed contacts that easily bend and then the machine does not detect the toner bottle. Unfortunately like everything in the MPC305, it is also a mission to replace.
                Press the GREEN button!!
                • Zaxxon
                  • 608
                  Normally I would replace this too.
                  • Cipher
                    It's not easy being green
                    • May 2006
                    • 1309
                    Looks straight forward enough, but it's quite a strip to get it to this point.
                    The BRB toner bottle connection board has been removed in this picture, but it sits just above the white gears.
                    A common fault is the plastic coil in one or more of the toner supply tubes will stretch and knot up restricting the toner supply.
                    I've also had faulty sponge seals that become partially unstuck and hang down from the main toner hopper chassis once again restricting toner supply.
                    Did someone say to throw this model out of the nearest window, not a bad idea.
                    • aktasson
                      • Feb 2017
                      • 201
                      As additional for help.
                      • jonhiker
                        • 661
                        Yep, not a fun job. If there is room, we usually use 2 people. I also replace all 4 colors wile I am in there.
                        • Tecnicopia
                          • Jun 2015
                          • 31
                          If you want to "solve" the issue for 3 or 4 months, do this:
                          Pull out fuser, transfer roller, transfer belt, Y toner, Y Pdcu, laser cover and laser units.
                          Vacuum with a new filter the yellow supply from toner emplacement while you open with the other hand the toner supply to the pdcu, just close and open and vacuum the toner hopper for 1-2 mins.
                          Rebuild the machine, and do 4-5 forced toner supply for Yellow only.
                          This take 30-40mins. Good luck.
                          Enviado desde mi Redmi 4X mediante Tapatalk
                          • Wild Bill
                            • Jul 2005
                            • 774
                            So your telling me, that if your out doing your job, minding your own business
                            and replace a PCDU on this model, It will jack up the machine?
                            Good luck telling a chargeable account that its not your fault.
                            Cause 1:
                            Initial symptom after the PDCU is replaced or just after the machine is installed.
                            Glad we don't have many of these
                            Izzy
