aficio 2035
  • Gab
    • Aug 2015
    • 671
    aficio 2035
    Paper jam occurs frequenrly at fusing. Paper jam one of upper picker fingers
    I replaced hot, upper piocker finger with no result .
    I note that copies are defficult (from books)
  • jonhiker
    • 661
    Re: aficio 2035
    Do the copies have a black margin on the lead edge? This can be a cause of paper jams. Also, the fusing exit sensor, which is in the duplex unit, pretty easy to see, can get flaky and needs to be replaced. Especially if your jam code is 14.
      • 37480
      Re: aficio 2035
      Are you sure you are using the proper hot roller strippers?
      • whitecat
        • Nov 2012
        • 43
        Re: aficio 2035
        Is very important to use the proper springs for strippers. Idk codes because it happened a long time ago.
        ( proper = a lilttle bit stronger springs , so it will be a lil harder for the paper to raise the stripper from hot roller )
        Last time i touched a 2035 was 2-3 years ago.
        • Wild Bill
          • Jul 2005
          • 774
          Re: aficio 2035
          Just seen one last week... It made me feel better about working on the 4/5000 series.
          Izzy
          • Iowatech
            Not a service manager
            • 3930
            Re: aficio 2035
            Part number for hot roller strippers: AE04 4056
            Part number for stripper springs: AA06 0948
            Info from the old DSD, sorry if it was a waste of time.
            2035 fuser 2.pdf
