MP C4503 Airprint with SOP
  • mikedci
    • Jul 2010
    • 227
    after installing the SOP the printer no longer shows up in the available printers list for airprint.
    went through rtb 35r all firmware utd
    device cert installed
    ssl/tls set to active
    airprint and bonjour set to on/active
    all other functions working...scan/print etc...
    thoughts?
    also sps for when changing to sop are set correctly, sp 1002-012 set correctly
  • dotdeas
    Senior Solution Consult
    • Aug 2015
    • 18
    Re: MP C4503 Airprint with SOP
    thoughts?
    • mikedci
      • Jul 2010
      • 227
      HTTPS is enabled
      • dotdeas
        • Aug 2015
        • 18
        HTTPS is enabled
        • mikedci
          • Jul 2010
          • 227
          no luck
          • mikedci
            • Jul 2010
            • 227
            Ended up being a firmware issue.
            Network Support 12.100.1(latest available atm) breaks airprint...Rolled back to 12.99 and working as intended.
