[error] Mp 3054 random paper jam ,PCU ,Fusing error
  • whitecat
    • Nov 2012
    • 43
    Hello i have a mp3054 with less the 100k copies with latest firmware. Randomly the machines gives : paper missfeed inside of device ,paper missfeed duplex unit , reset correctly BK PCU , reset correctly Fusing Unit. Not always in this order.When i check the logs for paper jams , shows only J001 ( paper jam at power up) .
    Any input is welcomed.
    • 37480
    Re: [error] Mp 3054 random paper jam ,PCU ,Fusing error
    J001 is normally a faulty cover switch. One of the small push button type like on bridge units and duplex units.
    • nikeccc
      • Aug 2014
      • 5
      I have the same problem and I have many blockages in the area SKEW correction sensor on= 44. You have found a solution for this issue?
      • nikeccc
        • Aug 2014
        • 5
        I have same situation and many jam in area SKEW correction sensor. You have found a solution to this issue?
        • sturmtrooper
          Copier Combobulator
          • May 2016
          • 587
          Please start a new thread about your issue.
