Page numbering when printing
  • Voltageza
    • Jun 2017
    • 71
    Hi guys
    Any body have an idea on how to page number a document when printing. Ex and .pdf doc
    I know its possible when copying.
    Customer has a MPC2011
    thanks
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Re: Page numbering when printing
    PCL6 v4 Driver for Universal Print
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      Yep, that will do it.
      Make sure you get the most current version of the driver, though.
      The current version is 4.17.
      Your model started being supported with 4.6, but I've learned through experience that the driver changes quite a bit (always for the better) between versions.
      • Voltageza
        • Jun 2017
        • 71
        Awesome
        Thanks a lot
        • sturmtrooper
          Copier Combobulator
          • May 2016
          • 587
          The V4 in the title likely refers to this the microsoft v4 driver model. Which ricoh does make a universal driver supporting that. Clear as mud right?
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            No.
            The driver being referred to is the Ricoh Universal PCL driver.
            It wouldn't use a Microsoft driver on a bet.
            • sturmtrooper
              Copier Combobulator
              • May 2016
              • 587
              No.
              Ricoh makes two universal PCL6 drivers. A regular one, and a V4 compliant one.
              • Cipher
                • May 2006
                • 1309
                Yes you can print from Microsoft Store apps using the new v4 architecture UPD.
