No Display MP C3002
  • sharpmind
    • Sep 2009
    • 478
    No Display MP C3002
    Guys, if the IPU is defective, will it damage the polygon motor? Is there a chance to repair the IPU and make it work again? What particular component of the IPU is to be repaired if possible?
    Thank you.
    • 37628
    Re: No Display MP C3002
    Polygon motors have been known the board that drives them. When that happens you will get a blank screen. To correct you have to replace both at the same time.
    • ridgemill
      • Sep 2017
      • 192
      Can you access the machine through the web manager?
      • sharpmind
        • Sep 2009
        • 478
        The original problem of the machine is SC 220-01. I made a request for a polygon motor in our office but the box that contains the polygon motor is not sealed. I did not bother myself to ask our store guy why it is open because I will just use it for testing only. So I went to client and I replaced the polygon motor. I was shock that the machine shows no display after replacing the polygon motor. I know that the IPU is damaged. I am thinking that the polygon motor given to me is defective that it damaged the IPU resulting to no display problem. The question now is, is IPU repairable?
          • 37628
          There was a tread where someone had posted a board level repair but I don't think it was the IPU. You can try searching blank screen and blank display problems with Ricoh.
          • Zaxxon
            • 608
            MPC2800/3300 display dead mc tries to start (SC202) - SOLVED!
            Please start you post with brand, model, problem.
              • 37628
              Post 13 in the thread has the picture. Original poster was polarbear. If you need any more information, you might PM him.
              • sharpmind
                • Sep 2009
                • 478
                As I traced the connector of the polygon motor, it is routed to the IPU (D1425150). Connectors of the LD (laser diode) boards are routed to IOB (D1445120). BCU is located to the lower part of the IPU, See attached photo. Is it IPU defective or BCU is damaged caused by the shorted polygon motor?Capture.JPG
                • fshead
                  • 2378
                  ive done it on a mpc2800 "still running 2 years later" and took the "tiny" tiny part off a bad board.
                  it isnt a walk in the park..you will need something to enlarge working area as
                  it is very small and a fine tip solder iron.
                  • fshead
                    • 2378
                    i thought it was the bcu board
                    • fshead
                      • 2378
                      but looking at your posted pics on the mpc2800 the board was a large brd..
                      • Oze
                        Ricoh Fanboy
                        • Jul 2008
                        • 1663
                        On the MPC2800/3300 it WAS the BCU that causes the Polygon mirror motor to fail.
                        They have to be changed at the same time to resolve the issue....as Slim stated in an earlier response.
                          Thank you.
                          hey man... not on this subject... but you posted about "can ping but not print" when you end the title of the topic in the word " print" we cannot reply to it ( dunno why ) you might want to go and edit that title. BUT you said you have a crossover cable attached... you cannot use that for "network" printing due to the pin outs. that's why you use one from your lapper to the machine.
