running 28lb 12 by 18 paper on a mpc3003
  • fshead
    • 2378
    hi
    if i have an account running 28lb paper thru the trays on 12 by 18 paper do i need to
    change any settings?either thru user tools or service mode?
    thanks
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    Re: running 28lb 12 by 18 paper on a mpc3003
    Originally posted by fshead
    hi
    thanks
    I usually set the tray priority settings to Driver Command.
    That stops the customer having to run back to the machine to change tray settings.
    They can do it via user preferences on the driver at the print stage.
    Have you checked the manual to confirm whether the stock being used is within spec?
      • 37628
      Fusing temperatures on the 03s are fairly tightly set according to paper thickness. Example SP1105 print target temp
      -013 M-thick FC center 135C
      -017 Thick 1 FC center 125C
      In User Tools - System - paper tray setting there is a section for paper thickness, also in the settings for the print driver. The MPC will use these thickness settings to adjust the fusing.
      • sturmtrooper
        Copier Combobulator
        • May 2016
        • 587
        hi
        thanks
        28lb what? Book, bond, index, cover? Either way yes that is likely heavy enough that the customer should select the correct paper weight in the machine and or printer driver for the tray it is being used in. Your best bet will be to find the grams per square metre equivalent as that will make finding the correct setting easier.
          • 37628
          Just remembered this morning, in order to use 12X18 or SRA3 paper does require installing the Image able Area Extension Unit Type M3.
          • fshead
            • 2378
            i dont know as they emailed me this question.i am thinking 28lb laser bond,
            i have not sold paper in 25 years,dont miss the workout either....
            • fshead
              • 2378
              if the trays can run 12 by 18 is it just a 1 inch void without that option?
              • fshead
                • 2378
                i have not cked specs but 28lb to me is not much on earlier series..If i remember 110lb run ok thru bypass on the mpc3501 at a few accounts
                • Oze
                  Ricoh Fanboy
                  • Jul 2008
                  • 1663
                  Coming from a commercial print background AND a Metric country we work in Grams.
                  I believe that the manual states that you CAN feed up to 320gsm from the trays but once you get wear and tear on the feed units it tends to cause issues but at 105gsm I wouldn't expect any issues other than what Slim stated about the over size sheet.
                  • fshead
                    • 2378
                    thanks
                    It turns out 28lb paper is 105g/ms.
                    And setting up the 2 tray and setting the paper weight thru user tools was a breeze.
                    it looks like i might have a 1/2 void on each side but very workable.
                      • 37628
                      thanks
                      Sounds like it does not have the Image able Area Extension Unit Type M3 installed, 1" wider PTR and some SP settings.
                      • fshead
                        • 2378
                        i never saw one and as i only sell lease returns units,they come in many different configurations.
                        I basically only care about the meter.......
