MP 7502 leading edge shift / Border Shift
  • jsr123
    • Sep 2012
    • 11
    [Misc] MP 7502 leading edge shift / Border Shift
    Dear All
    MP - 7502 while copying from DF leading edge shifting. As per bottom edge also shifting.
    sample copy attached for reference. From user tools edit margins set to all four zero. And
    centre border to
    1. Problem is erratic. 2. Copier is one year old with 150000 counter. 3. DF kit is new.
  • Zeldaman
    • Mar 2011
    • 946
    Re: MP 7502 leading edge shift / Border Shift
    Hi there!
    Look after the tension of the belts, dirt & old grease on the wheels driven by the belts (behind the 2 big motors ).
    Greetings...
    • jsr123
      • Sep 2012
      • 11
      Originally posted by Zeldaman
      Hi there!
      Greetings...
      Which motor. In DF Unit or drive side. Where ???
        • 37503
        Which is the lead edge? It could be jitter or the original not being held down at either the front or rear of the slit glass. Hard to tell without knowing the direction of travel.
