Browser unit uninstallation procedure on mpc3003 with PS3card merged
  • fshead
    • 2378
    greetings.
    I need a PS3 card for a mpc3003 and have one on a different mpc3003.
    That machine has the browser unit and I think it was merged onto the PS3 card"have not checked it all but remember seeing
    the browser card taped to inside cover under the control panel".
    I need to pull this card and dont want to screw up that machine.
    Do I just do the uninstall procedure,power down and remove the ps3 card?
    I didnt see any option to uninstall the ps3 card so is that all that is needed?
    thanks
  • fshead
    • 2378
    Re: Browser unit uninstallation procedure on mpc3003 with PS3card merged
    OR can i move the browser option via SP 5873-02?
    And I am kinda confused on what the manual says..
    when merging browser"slot 2" to ps3 "slot 1" i have done with other options but when
    doing undo exec the manual says as follows
    5873 [SD Card Appli Move]
    001
    Move Exec
    CTL
    [Execute]
    This SP copies the application programs from the original SD card in SD card slot 2 to an
    SD card in SD card slot 1.
    002
    Undo Exec
    CTL
    [Execute]
    This SP copies back the application programs from an SD card in SD Card Slot 2 to the
    original SD card in SD card slot 1. Use this menu when you have mistakenly copied some
    programs by using "Move Exec" (SP5873-1).
    • fshead
      • 2378
      this is what i see in the mpc3002 manual which is what i think is correct,ps3 in slot 1 and browser in slot2
      and then move browser option from ps3 to browser sd card..
      i dont want to regret not researching the right answer and regretting it afterwards..
      Undo Exec" (SP5-873-002) lets you move back application programs from an SD card in SD CardSlot 1 (upper) to the original SD card in SD Card Slot 2 (lower). You can use this program when, for
      example, you have mistakenly copied some programs by using Move Exec (SP5-873-001)
