ΜΠ 2501
  • Gab
    • Aug 2015
    • 671
    ΜΠ 2501
    In the first maintance of this machine i replaced opc , blade and developer but instand of executing 2 801 i executed 2 802. Ever since i couldn't fix the machine . Image at the center is not so vivd but acceptable but at the edges is light. Also dirty background.
    I have tried everything with no result. Cleaned optics, swaped a drum unit from an other machine, cleaned laser unit, separation roller with no results.
    During that period machine made more than 100k copies with poor image. I have replaced 3 times (3 maintence services) OPC ,blade and developer , executed sp 2 801 but the same problem . OPC, dev and toner are geniuin.
    I am sure that the problem is not at the drum unit or at the machine but some value somehow has changed .
    Any idea?
  • davel
    • Oct 2011
    • 1107
    Re: ΜΠ 2501
    Please confirm machine model.
    • sandmanmac
      • 3981
      Re: ΜΠ 2501
      Any idea?
      It's been 2 months since you posted THIS
      Maybe it's time to get some help from someone who knows what they're doing?
      And why have you started a new thread?!
      • limo
        • Jun 2008
        • 103
        Re: ΜΠ 2501
        Clean the surfaces of the polygon motor mirrors.
          • 37529
          Re: ΜΠ 2501
          Are you aware that all the mirrors inside a laser housing unit are first surface mirrors.
          • Gab
            • Aug 2015
            • 671
            Re: ΜΠ 2501
            MAchine is ΜΡ 2501 , Ι have cleaned laser unit and polygon mirror surfaces . As i have told you the problem started after first maintence . at that point image was not light but with dark lines because of the drum which i replaced. After maintence i have had those problems. So i don't think that laser is the problem. After all i have cleaned it with no result.
            I Repeat i believe the problem is at the machine perhaps when i first replaced developer and executed 2802 instead of 2801 somehow a value has changed.
            Now i have the same problem with an other mp2501 . Customer used compatible toner and machine splited toner. I replaced opc, blade and developer (all geniuin) executed 2801 and image is exactly as the first machine.
            Any idea?
            i.e. Because customer was absent all that time i lost interest for these machines but now.
            • eccelobo
              • 113
              Re: ΜΠ 2501
              Any idea?
              At the moment of adjustment, did you check the values for charge roller bias, development bias?
              Also, could you scan and post 5990-002?
              Enviado desde mi SM-G920V mediante Tapatalk
