RICOH 1140L Heater problem
  • lubsimram
    • Jun 2007
    • 19
    I have a problem on my RICOH fax 1140L there is message on display "Printer Error Fuser Temp." I already check the hardware Heater Lamp, Thermistor, Thermostat, all are ok and Good. Can someone help me how can i reset these trouble code.
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Set soft switch 1, bit 8 to "1".
    Reset/erase Printer Error: "▼" "#" "T"
    Cycle power off/on.
    • lvsb
      • Aug 2008
      • 70
      press the following keys:
      1. DOWN ARROW, *, #
      2.press OK
      3.press the #1 key and then OK
      4. press stop
      5. press the DOWN ARROW, #, then the UP ARROW key( machine will display T-PRINTER ERROR)
      6. press OK then reboot
