mpc4502 user codes issue
  • jtymabel
    • Aug 2008
    • 164
    Is there a way (sp mode) to mask/hide the user codes when they are being typed on the display (****). I also modified the driver to have a pop up for entering the user code. Customer wants this also masked.
    thanks
    • 37453
    Re: mpc4502 user codes issue
    Do they also want it to disable for one hour after 3 incorrect attempts?
    Maybe they need to use a higher level of user authentication than User Codes. Maybe Windows login, LDAP with Active Directory, Kerberos, CAC/PIV card or some other third party application.
    • jtymabel
      • Aug 2008
      • 164
      I'm sure they will ask for that. I was playing around with mp5054 and the codes are masked when you type .
      Sent from my SM-G955U using Tapatalk
      • jtymabel
        • Aug 2008
        • 164
        set up customer to use user codes for accounting and print limitations along with locked print for "security".
